Re: Farmall H Hydraulics
Posted by Owen Aaland on November 04, 2010 at 12:59:42 from (65.161.86.17):
In Reply to: Farmall H Hydraulics posted by Zachary Hoyt on November 03, 2010 at 17:48:10:
Probably the most common reason for the coupler and shaft to strip out the threads is the spring on the lever breaking and the piece that breaks off gets drawn up into the pump gears and locks them up. That spring being broken is also a reason for you not feeling any change as you pull on the control rod.
I doubt that you are going to find a new shaft. The cheapest repair will most likely be to replace the entire LiftAll pump with a used assembly. If you really need to repair what you have you could have the threaded portion of the shaft built up and rethreaded but if you have to have the work done at a machine shop the cost could be more than a replacement assembly.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
