Re: Farmall A charging system
Posted by Bob M on November 04, 2010 at 15:13:30 from (67.240.170.42):
In Reply to: Farmall A charging system posted by bkpigs on November 04, 2010 at 14:34:42:
At some point earlier in its life the original cutout was replaced with a voltage regulator. So presuming the VR is wired correctly the light switch "L" and "H" positions are now simply two alternate "off" positions for the lights. Thus the switch setting now has no effect the charge rate - that's now for the to the VR to perform.
You might try printing the generator/regulator troubleshooting chart (link below) then following it through to identify the problem.
