Re: Grease Zerk on fan on 48 H
Posted by Kevin Meier on November 04, 2010 at 15:30:39 from (208.90.10.155):
In Reply to: Re: Grease Zerk on fan on 48 H posted by Farmallb on November 03, 2010 at 14:28:27:
The fan should come right off after removing t-bar, 2 spring studs, and 2 bolts. The bearings are located insisde the pulley. Pull it off over the center water pump tube and knock them out with a punch and hammer. Replace both o rings when you are finished replacing the bearings.
