Re: Jump starting 6 volt H with 12 volt battery
Posted by jal-SD on November 04, 2010 at 19:39:06 from (208.53.222.169):
In Reply to: Jump starting 6 volt H with 12 volt battery posted by stevecl on November 04, 2010 at 19:19:06:
Connect neg and pos jumpers to neg and pos terminals on the 12 V. Then connect the neg jumper to neg post, then pos jumper to the point where the 6V pos is bolted to the frame (assuming that its still original pos ground) and hit the starter. As soon as its running disconnect opposite the way you connected. (My $0.02 worth. jal-SD)
