While jumping a 6 volt tractor from a 12 volt vehicle is not recommended (there's a risk of the both 6 volt and 12 volt battery exploding if done improperly) it can be done.
Several precautions:
1 - Wear safety glasses, and keep bystanders well back.
2 - Shut down the 12 volt tractor engine before making any jumper cable connections. Leave it shut down while cranking the 6 volt tractor.
3 - Now proceed as follows:
Make all the jumper cable connections EXCEPT the frame (ground) connection at the 6 volt tractor.
Next, with the 6 volt tractor throttle set at slow idle, hit its starter and make the final jumper cable connection at the same time (expect an arc when you make the connection!)
The instant engine fires, release the starter button and IMMEDIATELY disconnect the ground jumper cable. Do this to prevent the 6 volt tractor's voltage regulator cutout from closing with 12 volts present in the system, possibly burning the VR's contacts.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
