Re: Farmall .H, 6 volt starter
Posted by riverbend on November 05, 2010 at 04:42:09 from (74.46.176.129):
In Reply to: Farmall .H, 6 volt starter posted by stevecl on November 03, 2010 at 19:24:26:
I had a similar problem with my H and already had 0 gauge battery cables. The problem was that the springs for the starter brushes were weak. The undrlying problem was that the internal ground connection for the brushes was a little loose and overheated the springs.
You don"t have to take the starter apart to check the springs. Take the band off the back and pull on each brush (there are 4 of them) with a light spring scale. The tension should be 24-28 ounces.
Greg
