Re: Farmall A charging system
Posted by John T on November 05, 2010 at 07:51:37 from (66.244.97.31):
In Reply to: Re: Farmall A charging system posted by gene bender on November 05, 2010 at 04:33:05:
Some old Cutout Relays had 3 terminals BAT GEN and FLD but those arent really considered Voltage Regulators, just Cutout Relays that supplied a ground for the gennys FLD in tractors that DID NOT use a Low High charge light switch. If they used a LHBD low/high light switch and didnt have a VR only a cutout, then the Gennys FLD post is wired to that switch which supplies a resistive ground for Low charge or a direct ground for High charge. If it uses a full fledged VR (3 or 4 terminal) the gennys FLD wires to the VR ONLY NOT any light switch. HOWEVER if you went ahead n wired the gennys FLD to a Low High light switch it can still make her charge as it (NOT the VR) supplies the ground albeit not an auto regulation system (like with a VR) but a manual regulation system
John T
John T
