Re: Jump starting 6 volt H with 12 volt battery
Posted by John T on November 05, 2010 at 07:57:27 from (66.244.97.31):
In Reply to: Re: Jump starting 6 volt H with 12 volt battery posted by Faster346 on November 05, 2010 at 07:38:18:
Butttttttttttt weedhopper, a 12 volt charger (depends on its size) DOES NOT HAVE THE CAPACITY to supply something like 500 amps or more (depends on battery size) like a 12 volt battery could, plus a charger has some degree of safety overcurrent protection unlike a big brute of a battery. Ive used a 12 v charger to charge a 6 volt battery but used the low charge settings and dont leave it unattended for long periods n keep an eye on the battery so shes not over cookign or over boiling or excessive outgassing etc THATS NOT AS DANGEROUS AS A 12 VOLT BATTERY JUMP (several hundred amps capacity) ON A 6 VOLT BATTERY but still Id make the last connection on the frame away from the top of battery
John T
