I will agree with John T 100 percent and only add that a lot of the tractors we talk about on here like and H or M farmall the starter terminal is easy to access and 12 volting them is a pretty simple matter. When you get to the Farmall C and even a super H or M where they mounted the switch on top of the starter you are entering a whole different situation at that is the battery hot wire. Don't run 12 volts to that unless you unhook the cable from starter switch and then you will have to connect the accessory wire to battery cable to supply current to ign. Magnetic switch type like on 300 or 400 series tractors you can hook directly to starter, just stay away from the battery cable side and do not turn key to start position.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
