Re: Jump starting 6 volt H with 12 volt battery
Posted by NDS on November 05, 2010 at 14:08:26 from (98.81.11.21):
In Reply to: Re: Jump starting 6 volt H with 12 volt battery posted by mkirsch on November 05, 2010 at 05:09:46:
You may be right . I do not have 6 volt charger or battery but have checked voltage on 12 volt charger lots of times and got 15 volts maximum. MY trucks have 100 amp+ altenators and charge 14 volts maximum and 15.5 volts would put them in Red danger area on guage.
