Re: How do I pull axle from W6 ??
Posted by Charles E. McNelly on November 05, 2010 at 19:40:05 from (67.198.56.22):
In Reply to: How do I pull axle from W6 ?? posted by HLW on November 05, 2010 at 13:52:58:
I just replaced the outer oil seals, felt seals and bearings on my W6 4 months ago. Drain transmission oil. Pull the PTO out of the tractor. Remove the bolt and washer holding the bull gear on the axle. It"s the same bolt and washer as is on the other end holding the wheel on. Once you remove the bolt. pull the assembly out. You will need to heat the wheel spacer up pretty good to slide it off the axle. At first I thought it would be a hard job, but it went fairly easy. If you have any questions, just blast me an email and I"ll help as much as I can.
Charles
