Posted by pete 23 on November 06, 2010 at 15:06:09 from (184.12.34.48):
In Reply to: 806 frost plug heater posted by jdetig1 on November 05, 2010 at 19:40:28:
Not that you have done this , but some guys mistake the plugs in the cyl head intake for coolant plugs. More opinions here also, I much prefer the frost plug heater to a tank heater as a tank type can change the balance of the coolant flow through the head. They do have a reverse check valve in them but depending on how you hook it up some flow may go through the tank heater when running, not good. I use two frost plug heaters if they are small like 600 watt and then you can plug both in if needed, especially if it sits outside.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
