Re: Oil Seal on Farmall A Fan Hub
Posted by Haas on November 06, 2010 at 18:34:15 from (75.216.85.147):
In Reply to: Oil Seal on Farmall A Fan Hub posted by Doc Larry on November 06, 2010 at 07:33:44:
These don't have a shaft seal that amounts to anything. They are designed that way. Centrifugal force keeps the oil away from the shaft. If it is assembled correctly and not overfilled with oil, it should not leak. There is a little stand pipe in the fill hole to get the correct level. Fill it with oil with the fill hole at the horizontal level. Then turn the fill hole down and let the excess drain out. The stand pipe determines the correct level. Put the plug back in and you should be good to go.
