Re: MD Transmission shaft reinstall
Posted by Haas on November 06, 2010 at 18:38:24 from (75.216.85.147):
In Reply to: MD Transmission shaft reinstall posted by BruceS. on November 06, 2010 at 04:29:13:
Some say you can get the drive shaft back in without removing the cross shaft. I guess that is true, as I got mine out with the cross shaft still in there. However, I tried and tried to get it back in; could not and finally gave up and removed the cross shaft. So unless there is some trick I don't know, I would say remove the cross shaft and then it will go back together without a problem.
