Super A Wheelbearing
Posted by wcroom on November 07, 2010 at 06:35:45 from (65.41.169.201):
There are two felt washers in the front wheelbearing kit I got for my "53 Super A. One thick and the other thinner.
Removing the old bearing, or what was left, I found the thinner washer against the inner side of the spindle, the oil seal went on next. Does the thicker felt washer go between the inner and outer bearings?
The inner bearing had come apart, and I could find no trace of the thicker washer as I was taking things apart.
I"ve cleaned the spindle up with emery cloth to remove the burrs. Should I have to tap the races into the hub of the wheel?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
