Re: Hyd pump output B-414 and WD-9?
Posted by tractorsam on November 07, 2010 at 17:18:27 from (99.192.104.215):
In Reply to: Re: Hyd pump output B-414 and WD-9? posted by Wardner on November 07, 2010 at 13:14:56:
Thanks to both of you. The steering arrangement for the B-414 will be almost entirely cobbled and nowhere near perfect but it should make an otherwise unusable tractor serviceable.
As to the hoe, I am as yet undecided as to what I'm doing. I don't know how much luck I'd have finding a junk hoe and I didn't really want something quite that large. The only reason I'm thinking about the distributor pump is that (there is no pump on the '9' at the moment) I have a friend with a parts SWD-9 that I could take the pump off. Thinking I might be better off with something driven off the PTO then I can use it on any tractor and gear it up to keep the engine RPM down. Thanks, Sam
