Re: What determined brand of Carb on 100, 200, etc
Posted by outlar on November 07, 2010 at 18:34:43 from (74.198.8.58):
In Reply to: What determined brand of Carb on 100, 200, etc posted by couv on November 06, 2010 at 20:35:52:
There is some good threads on YT on this topic if you have plenty of time to search , I've tried to use the search function with very limited success, maybe there's something I'm doing wrong , dont know.
Any carb that works is the best 1, although everyone has there favourite's.
I worked on a 1 bbl this week-end that had a carb kit put in within 5 years or so ago and roughly a hand full of common ailments they should be fairly easy to diagnose, jUST TIME consuming getting them right, and it was a carter.
Zenith are well liked also. I found removing the needle and seat and lashing them together was helpful to get a positive open and close. And also doing the same when the carb was assembled blowing air in the fuel inlet with "your pipe's" right side up... then upside down so the floats/weights close the needle in the seat and stopping the flow of fuel. Then there's bushing's ,clean passages, proper assembly, good gaskets, good floats and movement range's, and engine valve's to pull a good vaccuum through the carb. Now I'm looking for a procedure to set the valve clearance's on a 113 ci.
