Re: Finally found an F-30
Posted by Nebraska Cowman on November 08, 2010 at 05:25:10 from (66.252.115.12):
In Reply to: Re: Finally found an F-30 posted by Tom Fleming on November 08, 2010 at 03:31:15:
W30, 10-20 use the same basic engine. 10-20 does not
use a water pump) F20 and F30 both use the K5 Zenith
carb. The true F30 carb will have a larger venturi
but for showing and going either will work. No, the
wheels are different. The F30 uses a larger bolt
pattern. Fronts will interchange though (may need to
change the seal lip)
