if you are using Pioneer tips on the hoses and coupling into the IH tips on the tractor the problem may be with the couplers. the IH couplers have a cone with a flat pin type end and the Pioneer ends use a ball. When they start to get worn the flattened tip slides off to the side of the ball when coupled and that allows the ball to partially close. That causes a restriction in one direction but the ball will be opened by hydraulic flow in the other direction. If you can push the cone with pin off to the side as you push in on it, that most likely is your problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
