Re: 560 gas dies under load.
Posted by bc on November 08, 2010 at 16:50:47 from (71.158.222.35):
In Reply to: 560 gas dies under load. posted by Pete D on November 08, 2010 at 16:18:18:
Unobstucted fuel line may not be enough. You need full flow into a gas can for 5 to 10 minutes or more straight. I'd get a few gas cans and drain your tank and then check the bottom. Only takes a few minutes and/or movement for rust and floaters in the gas tank to disrupt flow. Been down that road a lot. Fuel flow keeps up with an idling tractor but when full flow takes what is in the carb, it quits dead. May have had rust and crud partially block the carb passages. A cleaning and a kit will only be a temporary fix. Your nickel. Let us know how it goes.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
