Re: int 464 brake repair
Posted by Bill Lisbon on November 08, 2010 at 17:41:56 from (69.89.162.209):
In Reply to: int 464 brake repair posted by greasyj on November 08, 2010 at 11:12:12:
One way I've checked the brakes out on these tractors is to block off the line coming into the brakes at the final drive. Then pump up brakes and check for leaks. If this holds hook up a brake hand pump (the kind they use for bleeding brakes on cars)to brakes at final drive and see if it leaks down, if it does then the final dive have to come off and the O-rings need to be replaced.
