Posted by Owen Aaland on November 08, 2010 at 21:34:32 from (65.161.86.17):
In Reply to: 350 LP transmission posted by tleake on November 08, 2010 at 11:41:14:
Is the noise there with the clutch released in neutral? If it is you probably broke a tooth on the constant mesh gear in the front of the transmission. You can remove the belt pulley drive assembly or cover plate to see inside the transmission.
If the noise is there only while moving the problem most likely will be in the final drives or ring and pinion gears. Don't overlook the possibility of of a loose wheel causing noise.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
