Re: 560 gas dies under load.
Posted by Brownie 450 on November 09, 2010 at 04:44:10 from (66.43.241.198):
In Reply to: 560 gas dies under load. posted by Pete D on November 08, 2010 at 16:18:18:
Look in the gas tank with a flashlight to see if there is any foreign material which would plug the outlet. Our 560 Diesel got corn tassels into the tank [used on the picker] & they got into the outlet. We took the sediment bowl/ outlet off, & it had 2 tassels in it. Removed the tassels & no more problems.
Bye the way, the 560's came out 12 volts. My brother had a 560 gas & the resistor was on there for cutting down point wear. When starting, the coil was given full 12 volts by the extra terminal on the starter solenoid. Bypassed the resistor that way.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
