Re: Farmall 504 stuck in first gear!
Posted by mkirsch on November 09, 2010 at 05:24:17 from (64.80.108.55):
In Reply to: Farmall 504 stuck in first gear! posted by Red Planet Matt on November 07, 2010 at 08:13:45:
Matt,
If the oil is the problem, it's too late to change it. The damage has been done. Changing the oil is a good idea if the tractor is new to you, but don't expect it to fix any issues.
I doubt if it's a lubrication problem, though.
Does the tractor move, or die when you let out the clutch?
If it moves, it's probably the TA being out of adjustment. Pull the TA lever and it will shift.
If it dies, it's stuck in two gears at once. Remove the shift lever and realign the shift forks through the hole as prescribed.
