Re: Farmall H starting issues
Posted by old on November 09, 2010 at 06:56:19 from (4.245.8.254):
In Reply to: Farmall H starting issues posted by Andrew Kappers on November 09, 2010 at 05:19:37:
That can be caused by a number of things. If it has a distributor the starter could be getting weak and pulling to many amps for it to have spark so when you let off you then have the amps/spark. Could be a simple timing issue or could be a problem with just plain weak spark. I would start by making sure you have a good blue/white spark that will jump a 1/4 inch gap if you do not have that then you have a spark type problem
