Re: 1940 A governor questions - again
Posted by Chris on June 26, 2000 at 12:19:01 from (205.215.115.172):
In Reply to: 1940 A governor questions - again posted by Douglas Stockman on June 26, 2000 at 03:15:42:
I don't know much about A governors, but I know that increasing the throttle puts more tension on the spring. So, when you move the lever 6-10 teeth ahead to get the speed to increase, there is an awful lot of tension being put on the spring which leads me to think that you have some binding, rubbing, or sticking somewhere. My Cub behaved the exact same way, but after I pulled the governor and soaked it in kerosene, replaced my spring, and went through every linkage and every possible binding point, the tractor ran like brand new.
When the engine is off, you're supposed to get some play in the linkages--the flyweights aren't active anymore so there is no force resisting the spring. In fact, a way to check that the governor is working is to make sure the throttle snaps to full open when the engine shuts down.
Chris
Post A Followup
: Re: Re: 1940 A governor questions - again
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
