Re: 1968 656 D International Farmall
Posted by pete 23 on November 09, 2010 at 10:10:10 from (184.12.34.48):
In Reply to: 1968 656 D International Farmall posted by Mike Karban on November 09, 2010 at 09:58:56:
The 656 used two different ring gears on flywheel and pinion gears on starter so you need to match serial numbers or start counting teeth. About 25 years ago one of the mechanics in shop installed wrong drive, it worked but made a lot of noise and I went out and installed correct one at the customers farm.
