Are you sure that the drive OD is not too large to engage the ring gear teeth? You can't rely on tooth count to get the right size OD on the drive gear.
The parts book lists two different drives for diesel starters but one is for the Hydro and the other is for the gear drive. The one for the hydro is a ten tooth with a 32 mm OD on the gear. I did not find any specs for the gear drive transmission drive but I did come up with another ten tooth with a 40 mm OD and a twelve tooth drive with a 46.5 mm OD. The 46.5 mm is the drive that is used on the 30 MT starters used in the 706.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
