If it has battery ignition, and a dropping resistor (ballast resistor), bypassing it for starting with a switch will boost starting voltage allowing an instant start. If the switch is tiresome, a 6 amp diode could be placed in a wire from the starter side of the starter switch, allowing starter level voltage to get to the coil side of the resistor, and then not back feed to the starter (which would fry the wires). If a mag, Putting windings from a 12 volt starter in the 6volt frame will slow it down so that the impulse coupling will work. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
