Re: Farmall 400 motor fit in a M?
Posted by Janicholson on November 09, 2010 at 17:28:38 from (67.72.98.45):
In Reply to: Re: Farmall 400 motor fit in a M? posted by Ryan P Kelley on November 09, 2010 at 17:08:48:
There is, you need to use the M flywheel and or a combination of the larger clutch/FW, and very late M or SM Belly pump to assure clearance. Some mix and match is going to be the case.
If you use a late SM stage II or newer engine, it will have a live pump that is far and away better than the Belly pump any way. Jim
