Re: RE: 12 Volt Wiring Diagram
Posted by Bob M on November 10, 2010 at 07:51:12 from (67.240.170.42):
In Reply to: RE: 12 Volt Wiring Diagram posted by Sully Deshaw on November 10, 2010 at 06:34:04:
Sully - Presuming the OEM generator and starter are in good shape, the cheapest fix is to install new 1/0 or 2/0 battery cables. That and a fresh 6 volt battery will spin your H just fine. And it will still be "original".
For a wiring harness try Jim at Agri-Services: www.wiringharnesses.com. (I have no connection with Agri-Services. But their stuff is good and prices are reasonable.)
However if you prefer to convert to 12 volts the cheapest way is to mount a Delco 10SI series alternator ($20 or so at a junkyard/$50 for a rebuilt NAPA, etc). Then wire it up per the diagram at the link, making your own harness.
