Re: 560 gas dies under load.
Posted by gene bender on November 10, 2010 at 09:56:02 from (67.55.227.196):
In Reply to: 560 gas dies under load. posted by Pete D on November 08, 2010 at 16:18:18:
My guess would be the condenser as it seems like these new ones just cant be counted on. I would change that and then go. This if you are sure your fuel flow is good as they both can have same type problem. Had a condenser go bad on the first day of a tractor ride probably should have not even installed a new one to start with as the old one could have lasted for many more yrs.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
