Re: Int. 350 Utility
Posted by Jon on June 26, 2000 at 17:14:17 from (209.172.217.182):
In Reply to: Int. 350 Utility posted by Andy on June 26, 2000 at 16:28:20:
That is the Torque Amplifier. When pulled back(low range) it decreases the original gearing by 1/3. If a person doesn't know the proper way to shift these, you can burn up the TA clutch after a while. They should always be shifted in and out quickly and firmly, so don't let the clutches slip when shifting. Happy tractoring.
Post A Followup
: Re: Re: Int. 350 Utility
