Re: Notched tooth throttle assembly (instead of saw tooth)
Posted by paramedicchuck on November 11, 2010 at 05:18:11 from (174.103.237.211):
In Reply to: Notched tooth throttle assembly (instead of saw tooth) posted by ScottyHOMEy on November 10, 2010 at 18:24:13:
At higher RPMs, it doesn't hold as well as a notched tooth. I thought about the friction throttle, and still may go that direction, but like the more 'original' look of the notched tooth and thought I would try that route first.
