Re: Farmall H Govenor.. Idles and then races
Posted by Full Throttle on November 11, 2010 at 05:46:10 from (4.225.94.129):
In Reply to: Re: Farmall H Govenor.. Idles and then races posted by roger hall on November 10, 2010 at 19:51:29:
That little thrust washer that rests on the weights has wear spots in it, this washer has to rotate and what happens is it gets locked on those spots, then it releases and rpm goes crazy till it settles back in. Along with the conbination of worn weight pins, bad roller bearing on the linkage shaft causing binding.
If the washer is all you find, simply flip it over. might not be whats wrong, but its a start to look.
