You can put the 3.250" sleeve kit in that engine. You can install a water pump if it doesn't have one. Be sure to clean that block area thoroughly where the old seals were installed. Once you're ready to install your new sleeves coat the lip of the sleeves with dish detergent so they slide into the new seals easily. Make sure you have your crankshaft measured for wear at your local auto machine shop. They will determine if it needs to be ground undersize. Have the machine shop to furnish the correct bearings. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
