Re: Notched tooth throttle assembly (instead of saw tooth)
Posted by Faster346 on November 11, 2010 at 14:32:48 from (72.241.169.131):
In Reply to: Notched tooth throttle assembly (instead of saw tooth) posted by whiskey bent on November 10, 2010 at 18:24:13:
My H has a notch style throttle and my M has the sawtooth, and they both don't hold for manure in higher RPMs. I have to use a small clamp with both. The notches are perfect and the spring is tight as well. My old H that I sold a while back had the M&W friction type throttle on it, and it stayed wherever put. I might go that route on my current tractors.
