Re: Oil sender location on 263 gas engine
Posted by bc on November 11, 2010 at 16:33:51 from (71.158.222.35):
In Reply to: Re: Oil sender location on 263 gas engine posted by Janicholson on November 11, 2010 at 09:42:15:
Thanks. I'm about to that point or else I'll put the steering wheel and throttle back on and do it later. I'll see what Oreillys or napa has for steel. If I end up using metal, I'd rather flare it than use compression fittings which are hit or miss for leaking. By the time I buy the fittings and stuff, might be just as easy to go electric but those senders aren't bullet proof either.
