Re: Need rebuild parts for TD-6 timing gear mount Hydraulic Pump
Posted by Les Repair on June 26, 2000 at 18:54:38 from (206.28.174.173):
In Reply to: Need rebuild parts for TD-6 timing gear mount Hydraulic Pump posted by Anton on June 26, 2000 at 10:50:40:
I think that engine was used in M and Super M tractors. If the pump has an aluminum housing, it would likely be like the one used on Super Ms. If the pump is weak I think all you can do is replace it. There are some aftermarket pumps which are available that aren't as high priced as Case IH. It'll scare you.
Post A Followup
: Re: Re: Need rebuild parts for TD-6 timing gear mount Hydraulic Pump
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
