Sawtooth throttle controls are actually relatively easy to repair if you have access to a welder or can weld yourself. Run a heavy bead of weld along the worn teeth and on the single tooth on the handle.
Rough shape with weld with a bench grinder on both parts. Use a mill file to recut the notches into the throttle plate and the handle. I did one last year, took me about 3 hours to weld, grind, and file.
With a coat of paint on, you wouldn't know that it had been redone.
One last hint, I put a slight twist/bend in the handle so that the "tooth" in the handle engages the plate more agressively. Imagine a right triangle with the veritcal side to the right. both vertical surfaces (plate and handle) should be exactly parallel when they make contact. That is the slight bend that you may have to put in the handle.
as always, IMHO.
This post was edited by Tom Fleming at 01:52:15 11/12/10.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
