Re: Notched tooth throttle assembly (instead of saw tooth)
Posted by rustyfarmall on November 12, 2010 at 05:29:54 from (209.152.78.140):
In Reply to: Notched tooth throttle assembly (instead of saw tooth) posted by Bud W on November 10, 2010 at 18:24:13:
The other end of the handle wears out also, and will even cut a groove into the underside of the plate. If you build up the end of the handle, and fill in the groove, you shouldn't need to "bend" the throttle handle.
