Re: radiator shutter help
Posted by Dean Olson on November 12, 2010 at 19:06:56 from (76.31.42.124):
In Reply to: Re: radiator shutter help posted by bmagee on November 12, 2010 at 18:42:34:
The crank has a collar on the drivers side of the plate and has a pin holding it on the crank body. Clean up the paint/rust to find pin. Drive the pin out. Collar will probably be rusted to crank body gently pry it off. Lots of penetrating oil, patience, and probably some heat. Trying to find that crank is getting harder. I looked at well over 50 H&M Farmalls to find 1 I could use.
