Re: My Farmall H quick resto before after pict
Posted by The Dukester on November 12, 2010 at 20:08:30 from (209.86.226.52):
In Reply to: My Farmall H posted by Faster346 on November 09, 2010 at 17:32:50:
Not bad....You could have been a little more careful when applying the decals. The "Circle H" should be concentric with the hood rib curve and the IH FARMALL decals centered on the hood between the rib curve and the back edge. Rear tires are just like the Goodrich 11-38's that were on a new H my uncle bought in 1950....they might mean that your tractor never did too much work if they are the originals...one thing for sure, that tread pattern wasn't used on regular tires after about 1953-1954. Tractor will look a lot better with the grill insert installed
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
