Farmall B high idle
Posted by 45farmallb on November 13, 2010 at 16:35:27 from (74.235.187.222):
I just finished putting my B back together, i got it started but it runs wide open.The rpm wont change when you move the throttle lever, i have to disconnect the rod from the lever and push it to get it to idle down.I adjusted the carb lever per I&T manual,i psuhe the carb lever and governerarm all the way forward and adjusted as manual stated and it actually got a little worse, so i backed it off a little bit past orignal adjustment and its a little better. Any suggestions. Thanks Brandon
