Posted by rustyacresnd on November 13, 2010 at 16:38:54 from (69.84.76.166):
In Reply to: Farmall H wont start posted by krs on November 13, 2010 at 15:51:13:
You could try hot wiring the ignition. Connect a jumper wire (preferrably fused) from the pos. post of the battery to the + terminal of the coil. This is assuming that the tractor is set up as neg. ground. If the tractor starts and runs this way, then you have bad connections, wiring or ignition switch. I've had ignition switches with bad contacts act this way.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
