HY-tran will work fine, only if your seals are not already leaking, they will be. When hy-tran was put in my super H, it blew out all of my seals, because hydraulic oil is too thin, for a system that was designed to work with motor oil. I would suggest using 30 weight, as that what was originally called for. Only of course do NOT use detergent oil as it will foam. Also do not use this with modern day implements that take hydraulic oil. I have also heard of guys using 90 weight gear lube, with good sucess. only do not expect to be able to use this in any kind of cold weather, as it will be like molassas.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
