Re: Farmall and W6 Bull Gears
Posted by D Slater on November 14, 2010 at 03:27:28 from (184.15.7.179):
In Reply to: Re: Farmall and W6 Bull Gears posted by Grabatire on November 13, 2010 at 19:55:11:
Guess I misunderstood, thought you just wanted a good housing for the M. If wanting to fix the W6, the ring and pinion from the M will work but slow the tractor down in all speeds. Guess since you don't have the transmission sliding gears with the 6, The M transmission gears will need swapped in. Another thing to keep in mind depending on ring and pinion used is the transmission rear main shaft bearing housing. Different for 6 and M main or pinion shafts.
No axle or housing change needed if fixing 6.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
