Posted by rustyfarmall on November 14, 2010 at 06:36:04 from (209.152.78.140):
In Reply to: M valve clearance posted by D Slater on November 13, 2010 at 15:25:01:
Yes, that 0.020" figure is what I came up with simply by guessing. I just couldn't get my ol' M warmed up enough, and when I set the valves at 0.017", the engine would not run good when it DID get warmed up, so I set the valves at 0.020" while the engine was cold, and it worked out pretty good. I've had other folks tell me that 0.022" COLD works out well also.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
