Posted by Brian Jasper co. Ia on November 14, 2010 at 10:16:42 from (72.171.0.149):
In Reply to: Farmall H wont start posted by krs on November 13, 2010 at 15:51:13:
Have your battery tested. I'll bet money it has a bad cell. With a 12V system, you need to keep cranking voltage above 9.6V for the ignition system to work. Under compression pressure, higher voltage is required to jump the same gap in open air. From your description, you probably had an ignition problem that you fixed by tuning the engine. Your starter is 6V and still works well because the voltage is staying well above 6V while cranking.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
