The 2001 with no down power has single acting hydraulic cylinders ( power up, gravity down), hence only one hose was connected to your outlets on the left side. 2000 loader has double acting ( power up and down ). It requires hoses to be connected to both outlets on left side. No changes to valves or settings. Just hook them up and go. They should however be connected so that you pull lever back to raise loader and push lever forward to lower loader. With down pressure continuing to be applied after loader bucket hits ground , loader will lift front wheels of tractor off the ground .
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
